01-04-2020 06:23
01-04-2020 06:23
Hi, I'm thinking about getting a versa but I cant wear my watch at work but I can have my phone, so I wondered is it possible for me to transfer my steps recorded on my phone to my versa when I get home?, I have a samsung galaxy, and use s health for step tracking.
01-04-2020 07:07
01-04-2020 07:07
Hello @Shane24v and a warm welcome. I did a little search and found this thread that is from early last year. The short answer appear to be no. You should search the Android forum. You might find a different answer. The Android forum is the best place to search for this information.
Also, just to be complete, there is a feature call MobileTrack, where you make your phone your tracker to track the basics. Unfortunately, most Android phones do not support MobileTrack. To be sure, tap on your profile pic > + Set Up a Device. If you see a screen like this, then your phone supports MobileTrack.
Even if your phone supports MobileTrack, Android has a weird limitation. With Android, you can have a Fitbit tracker or MobileTrack, but not both.
The cards seem to be stacked against you. The "Versa" model has been replaced by the Versa 2. No matter what you get, it sounds like it will be in your pocket at work.
Laurie | Maryland
