04-06-2018 17:38
04-06-2018 17:38
So this is very, very annoying! The Versa constantly loses the settings in the Exercise app. Things like lap settings, customized stats, auto-pause, etc. So frustrating to have to reconfigure the exercise from scratch every time. Having said that, the weird thing is not all the stats are being reset, for example pool length thankfully seems to be saved and doesn't reset.
It's even more annoying because the default settings duplicate the top/bottom stats in those selected for the middle. Why would you want the same information to take valuable "tap" space? Answer - you wouldn't!
It does make you wonder how "road tested" such products are, anyone using the device would have spotted such a frustrating issue very quickly. Let's hope they can remedy ASAP.
05-14-2018 20:31
05-14-2018 20:31
Forgot to mention that I couldn't set lap distance until I updated the app to the latest version.
05-17-2018 11:45
05-17-2018 11:45
Still loose the customized running settings after the latest update. Every time I go for a run I have to re-set the settings. Very annoying.
05-19-2018 07:28
05-19-2018 07:28
Yep, this is still broken.
05-27-2018 13:08
05-27-2018 13:08
Bought my Versa May 23/18. Went through updates.. and noticed customized stats reset to default everytime I exit the exercise.. Yes, very annoying for me to keep changing to my preference. Anyone know a solution? or we have to wait for Fitbit update to fix...
07-10-2018 22:26
07-10-2018 22:26
Does anyone in Fitbit actually cares about fixing bugs? How could this go unnoticed? Get yourself together because Samsung Galaxy and Google Pixel watches are coming and you really need to step your game up in terms of software...
08-01-2018 08:44
08-01-2018 08:44
Just purchased my Versa a couple days ago and had no idea this was an issue. Hopefully they can finally fix this bug soon!!
10-16-2018 12:33
10-16-2018 12:33
So is anybody from Fitbit going to acknowledge this issue and confirm it's been raised as a bug to be fixed?
Or is there some other process we should use to get that done?
10-16-2018 12:40
10-16-2018 12:40
I've been dealing with this same issue on my ionic, so it's not a small problem. Very frustrating.
