Versa display not working correctly - Won't sync either
my versa will not work. I’ve have for almost 2 months now. It turns on but the home screen is gray and shows nothing. Every time I click on something, like exercise or alarms, for example, it doesn’t do anything. It won’t sync with my phone either.
Moderator Edit: Formatting
1 REPLY 1
Hi @Starfish.fritos, welcome to the Community Forums!
Thanks for bringing this to our attention and for the details that were shared in your post. If you haven't already done so, I recommend you to check how the syncing procedure works here and see if there's a missing requirement on your mobile device that's preventing the syncing procedure to be completed.
Then, you can move forward and try the troubleshooting steps that are specified on: Why won't my Fitbit device sync? and let me know how it goes. Such help article includes a restart process that should fix the display issue you're also experiencing.
Let me know if further assistance is needed and if you have any additional questions.
