04-03-2019 09:54
04-03-2019 09:54
Versa does not vibrate, under any notice. What can be done?
Best Answer04-04-2019 21:44
04-04-2019 21:44
Best Answer04-03-2019 10:20
04-03-2019 10:20
Hi, first of all check in the settings of your Versa if vibrations are enabled. If yes, restart your Versa 4-5 times in a row by pressing and holding the left and right lower buttons together untill you see the Fitbit logo and release the buttons. Also check within your Fitbit app if vibration is enabled. Go to notifications, press it and scroll down to "Always vibration" and enable it when it's not.
Best Answer04-03-2019 22:11
04-03-2019 22:11
I forgot to say I have Versa Lite
Best Answer04-04-2019 04:32
04-04-2019 04:32
I have checked all my notifications and restarted my Versa. I’m still not getting vibrations with texts or calls. Any other things to try?
04-04-2019 20:51
04-04-2019 20:51
I reloaded Versa 5 times. But the vibration did not work (((((((Even the alarm clock works without vibration. What should I do next?
04-04-2019 21:44
