11-10-2019
12:07
19:10
DavideFitbit
11-10-2019
12:07
19:10
DavideFitbit
hi
i have just been given for a birthday present Versa 2
how do i clear or factory reset my original versa before i sell it ?
TIA
Moderator edit: format
See How do I erase my Fitbit device?
Make sure you do a sync first to make sure any data on tracker gets to Fitbit database.
@alzblade wrote:Thanks
but how do I reset the Versa ?
Did you actually go to that link and read what it said? I'm guessing you didn't because it gives the answer to your question right there.
Best AnswerSince you wanna be a smarta**. You information in the link your provided isn’t helpful at all to my question that brought me her, or to the original persons. They clearly asking how to factory reset a Versa 2. Your link only shows how to do so with a Fitbit Charge
