11-10-2019
12:07
19:10
DavideFitbit
11-10-2019
12:07
19:10
DavideFitbit
hi
i have just been given for a birthday present Versa 2
how do i clear or factory reset my original versa before i sell it ?
TIA
Moderator edit: format
11-10-2019 12:13
11-10-2019 12:13
See How do I erase my Fitbit device?
Make sure you do a sync first to make sure any data on tracker gets to Fitbit database.
11-10-2019 12:13
11-10-2019 12:13
11-10-2019 12:20
11-10-2019 12:20
Thanks
but how do I reset the Versa ?
Best Answer11-10-2019 13:50
11-10-2019 13:50
@alzblade wrote:Thanks
Did you actually go to that link and read what it said? I'm guessing you didn't because it gives the answer to your question right there.
Best Answer05-08-2020 04:57
05-08-2020 04:57
Since you wanna be a smarta**. You information in the link your provided isn’t helpful at all to my question that brought me her, or to the original persons. They clearly asking how to factory reset a Versa 2. Your link only shows how to do so with a Fitbit Charge
