09-06-2020
13:06
05:11
09-06-2020
13:06
05:11
my versa has not tracked anything (heart rate, sleep) since 12 August..I have tried resetting it but it hasnt helped. It does not show current heart rate on the screen
09-06-2020 13:26
09-06-2020 13:26
See if this article helps you - click to read.
09-06-2020 22:36
09-06-2020 22:36
I have done all the above and it is still not working -according to my versa I have had no heartbeat and no sleep since 12th August
Best Answer09-07-2020 13:49 - edited 06-12-2024 05:18
Hi there @KMC08, welcome to the Community Forums. Thanks for the details provided in your post about the heart rate and sleep data that haven't been tracked on your Versa since August 12th. I appreciate you've tried to fix it on your own and by following @Odyssey13's advice.
In order to move forward, would you mind confirming that you've tried the suggestions below:
Keep in mind that in order to get sleep stages you must receive heart rate readings.
Let me know if the heart rate is still missing on your watch or in the Fitbit app. I'll be around, keep me posted.
09-07-2020 14:03
09-07-2020 14:03
Thank you for your help. Unfortunately it has not resolved the problem.
Best Answer09-07-2020 14:25
09-07-2020 14:25
Hi there @KMC08, thanks for getting back and for the update. I appreciate you had followed the tips and recommendations provided above. Since this sounds a bit more serious, I've created a support case on your behalf - you should receive an email from Customer Support at the email you used to register with the Community forums. Note that we may take a bit long to get back to you since due to recent events affecting our operations, support options are limited and wait times are longer than usual. If you have any questions, don't hesitate to let me know.
