04-05-2019
10:07
08:26
MarcoGFitbit
04-05-2019
10:07
08:26
MarcoGFitbit
Is there a problem with me or the app? I can't get my New Limited Addition Versa to sync.
04-05-2019 10:57
04-05-2019 10:57
There were syncing issued earlier and when I went into the app I found it had logged me out. Are you still logged in?
Best Answer04-05-2019 11:16
04-05-2019 11:16
My Versa has not been syncing for 24 hours. What’s up?
04-05-2019 11:21
04-05-2019 11:21
After latest application update (Android) I have to shutdown and boot up versa every day (or even more often) to allow it to sync.
04-05-2019 12:14
04-05-2019 12:14
yes I am.
Best Answer04-05-2019 12:20
04-05-2019 12:20
on the night of the clock change and has not synced since!!
04-05-2019 12:20
I've been having this issue for a couple of weeks now. I thought I was the only one, specifically came here looking for help. Fricking crazy, I've tried factory resetting the device and my phone and it still happens.
Honestly, the more and more I deal with this device, the more and more I wish Pebble were still around.
Best Answer04-05-2019 12:22
04-05-2019 12:22
Hi, when you press the watch icon on top of the screen on the right side in the dashboard of the Fitbit app. does it still say "Versa", e.g. is the Versa still connected to the fitbit app??
Best Answer04-05-2019 12:24
04-05-2019 12:24
Yeah, it shows it's connected. I have all day sync and always connected turned on as well, for some reason, the notification for always connected doesn't appear either.
Best Answer04-05-2019 12:29
04-05-2019 12:29
Hi, log out of your fitbit Account, restart your Phone, start Fitbit again and login. Maybe that solves your problem.
Best Answer04-05-2019 12:37
04-05-2019 12:37
Thanks, I've tried that before already, seems to fix the issue for about a couple of hours. Then notifications stop coming through. Then I check the app and see that's it's also stopped syncing again. I've been stuck in a Groundhog Day cycle of repeating the same thing over and over again, it's pretty frustrating.
Best Answer04-05-2019 13:08
04-05-2019 13:08
BTW, do you have battery drain issue?
It looks like as soon as I loose sync/connect my versa start draining battery like crazy.
Shutdown of Versa (not just restart) helps so far for short period, day or two.
Best Answer04-05-2019 13:11
04-05-2019 13:11
I haven't had any kind of weird battery drain issues so far. Just syncing. My battery life appears to still be about 3-4 days, even when not syncing lol.
Best Answer04-05-2019 13:56
04-05-2019 13:56
OK thanks for all the help but what I did was push the left side button and the right side bottom button together until I got the fitbit sign(the diamond with all the dots). Then I went to the app and did a sync and it asked me if I wanted to link fitbit with versa and I said yes....YIPPY all of my info for 2 days was there. I hope it lasts.
Best Answer04-05-2019 14:10
04-05-2019 14:10
Congrats and thanks, that's why I'm around to try and help users with problems!
Best Answer04-09-2019 08:31
04-09-2019 08:31
Hello @Yvonnie55, @LCS and @dmwilson220 thanks for joining the Fitbit Community, it's great to have you on board. It's nice to see you too @DaAQVWwV, @SunsetRunner, @szpakJ and @SunsetRunner I hope you're doing well.
First of all, I would like to apologize for the delay in the response. I appreciate your participation in the Forums and for sharing your experience with us. I would like to thank those of you who have come back and let us know your Versa is now syncing, I'm very glad. Also, those of you who have already tried to troubleshoot this issue, thanks for letting us know.
If you're still having trouble though, I would like to suggest you to check the following:
If your device still won't sync, try these steps:
Give these steps a try and let us know in case you need further assistance. Have a great day!
