09-12-2019 23:29
09-12-2019 23:29
Hi all.
My Versa heart rate isn't working. I've checked and it is set to on, I've also done a hard reset.
Can anyone help?
Thanks.
09-13-2019 02:07
09-13-2019 02:07
Hi @Robo82 Is the green light flickering rapidly on the back of the Versa? Try turning the HR off on the versa's settings app, restart the Versa several times, and turn HR back on. If it is still not working please come back here.
Helen | Western Australia
09-13-2019 03:05 - edited 09-13-2019 03:05
My replacement Versa stopped working last week, heart rate erractic up at 160 whilst sitting down at work, sleep stopped tracking as well due to heart rate issues.
Checked the back of the watch and condensation in the sensor so that's the reason its not working. I done reset / turned on and off and factory reset.
Now this morning I have the black screen of death, watch is still working as I can feel it vibrating but screen is gone, waiting on my replacement.
Best Answer09-13-2019 06:56
09-13-2019 06:56
The green light isn't flashing at all.
Best Answer09-13-2019 07:29
09-13-2019 07:29
@Robo82 Did you try turning it off as I suggested above?
09-13-2019 11:15
09-13-2019 11:15
I did yes.
I turned it off, reset it 5 times then turned it on. No change unfortunately.
