06-12-2018
19:43
07:51
AlvaroFitbit
06-12-2018
19:43
07:51
AlvaroFitbit
Hello group...received new fitbit Versa yesterday. Set-up went well however it appears that the BPM Sensor is not working properly. On my wrist it doesn’t register...the band is tight so i feel the sendor is on my skin. When i remove it from my wrist and place a finger on the sensor it will turn green intermitantly. Is anyone else experiencing this problem. I have had the “Charge” for a few years and have not experienced this problem. Any ideas?
I wanted to give a shout out to all those who replied and assisted me in my BPM Sensor problems. I took all of the suggestions for action...contacted support as well. Fitbit's support service is the best that I have encountered of any large corporation. I am now enjoying a properly working Fitbit Versa. Kudos to all who assisted me. Thank you.
@Oldsalt66 @KismetJ It's great to see that you've visited the Fitbit Community! Sorry to hear that your heart rate isn't being read correctly. I suggest you clean the back of your Versa with cotton and rubbing alcohol. Restart it by doing the following:
1.- Press and hold the back (left) and bottom buttons until you see the Fitbit logo on the screen. This should take less than 10 seconds.
2.- Let go of the buttons.
3.- If your Fitbit watch doesn't work normally, use the instructions in How do I turn off my Fitbit device? to turn your watch off and on again.
Also turn off the heart rate, save and sync then turn it on again and save and sync your Versa.
After this follow these suggestions to improve the heart rate reading.
Let me know how it goes!
06-13-2018
10:23
11:18
JuanJoFitbit
06-13-2018
10:23
11:18
JuanJoFitbit
The directions on the the fitbit help guide instruct me to go to the Heart Rate Settings in my app and after following these directions several times. There is no Heart Rate Setting that allows me to turn it off and on, in my app at all. There is one on my phone but not in my app.
I have turned my phone off and on a few times and my resynced my app and watch and this does not seem to change anything. But, i am a bit perplexed about where the heart rate settings should be because when i go into my app and click on my watch as a device, Heart Rate is not an option at all.
IT also does not change that in my exercise summary, my Calories burned still shows --
this is from the help guide:http://help.fitbit.com/articles/en_US/Help_article/1565/#ImpactsAccuracy
For all devices except Ionic and Versa, you can try changing your Heart Rate setting from Auto, which means the heart-rate tracker is usually active when you're moving, to On, which means the heart rate tracker is always active. For Ionic and Versa, make sure the Heart Rate setting is On. For additional troubleshooting, see Why don't I see my heart rate on my Fitbit device?
Moderator edit: merged reply
06-13-2018
10:26
18:40
DavideFitbit
06-13-2018
10:26
18:40
DavideFitbit
Thank you so much! When I went into Settings [on the device itself], I noticed that Heart Rate was turned off! I had just changed the band and I must have done that while fiddling with the band pins. I'd suggest that anyone who isn't seeing heart rate should check Settings to make sure that they didn't accidentally turn the feature off before they try anything else.
[Edited to add the note that it's the Settings on the device itself.]
Hi everybody, hope everyone is doing fine and I apologize for the delay in my response.
@KismetJ not sure what you mean when you say that the phone shows heart rate but not the app. I am talking about the Fitbit app on your phone or you can check the settings area on the Versa itself to change these settings.
@MM1772 happy to hear that the instructions in this thread helped you resolve the issue.
@Oldsalt66 thank you for letting us know that Support helped you and that you are back on track now!
I'll be around!
@Vbai45 sorry for the delay in my response. Thank you so much for your reply and very happy to hear that the suggestions helped you fix this issue. I am sure this confirmation will help other members in the same situation so thank you again. Hopefully you will reach your fitness goals in no time.
I'll be around!
Best AnswerHi
my versa has not worked properly for days - I’ve been on gear trying to figure out why it’s stopped reading my heart rate. The green lights have not flashed on the back for days.
i have tried resetting the Fitbit a number of times and it’s made no difference.
I keep seeing posts saying turn heart rate monitor on and off and re synch.
as far as I can see there’s no option on the verses or the app to do this.
Move also going into the settings on the app and still I can’t see any way to do thia.
could someone please send or post step by step instructions? Thanks Katie
I don't know if you've tried this yet, but this worked for me.
On the Versa device, click the Settings icon (the one that looks like a gear).
You'll see settings for Brightness, Backlight Display, and Vibrations. Swipe up. The setting after Vibrations is a setting called Heart Rate. Make sure that says On.
Best AnswerI can't remember if I had to do anything else, but if you're running a Fitbit app on your phone, try closing the app and restarting your phone.
@AlvaroFitbit wrote:@Oldsalt66 @KismetJ It's great to see that you've visited the Fitbit Community! Sorry to hear that your heart rate isn't being read correctly. I suggest you clean the back of your Versa with cotton and rubbing alcohol. Restart it by doing the following:
Thank you sooo much for your answer, even though it wasn't my question!! My Versa stopped reading my heart rate a few days ago, and I was practically heartbroken because it took me months to save up enough to buy it. I tried shutting it down and turning it back on and it worked!!!
12-16-2018
08:36
15:13
12-16-2018
08:36
15:13
@Curry4 Welcome! It's nice to have you on board! Sorry for the late reply. Happy to hear that the restart helped solve the issue with your Versa not reading your heart rate. Hopefully you are back on track and getting all those daily steps.
I'll be around!
