09-07-2020
06:52
10:49
09-07-2020
06:52
10:49
Over the last few days my Versa is acting strange. Charge does not last more than 24 hours. It is losing time and days. When put on the charger it will set to correct date and time but only for a short while. I have been looking to find a fix and am unsuccessful.
I have owned several fitbits over the last few years and never had issues. They have always worked fantastically.
I hope someone can offer a solution.
Hi there @christensenc955, welcome to the Community Forums. I'm sorry to hear about your Versa's recent behavior. I understand how you must be feeling, thanks for the details provided in your post I'll be glad to help you with this.
Regarding the battery short life, I suggest taking a look at this help article: Can I extend my Fitbit device's battery life?
However, as per the description or your post, it seems that your Versa is not having a sufficient power source when you charge it. So I wondered, where you do your charge it? Have you checked if the USB port or outlet is faulty? If you haven't done so, try a different port. A UL-certified wall charger will also work, please don't use a USB hub. For best results, don’t leave your device plugged in on the charger longer than overnight.
If by any chance you face with charging difficulties, please check the steps below:
About the time and date not showing correctly on your watch, keep in mind that your Versa may be showing an incorrect time since it hasn't synced yet or if it hasn't been properly paired to your Fitbit account. Your Fitbit grabs the time of the device you're syncing with.
To see when was the last time your watch synced or check if it's still paired to your Fitbit account, tap the Today tab > your profile picture > your device image.
If your watch is unpaired, please set it up again by following the steps at: How do I set up my Fitbit device?. On the other hand, if your watch has not recently synced, follow these troubleshooting steps: Why won't my Fitbit device sync?
Hi there @christensenc955, thanks for the update. I'm sorry to hear that you're feeling frustrated due to these inconveniences, I understand where your concern is coming from. I appreciate you had followed the tips and recommendations provided above. Since this sounds a bit more serious, I've created a support case on your behalf - you should receive an email from Customer Support at the email you used to register with the Community forums. Note that we may take a bit long to get back to you since due to recent events affecting our operations, support options are limited and wait times are longer than usual. If you have any questions, don't hesitate to let me know. 🙂
Best AnswerI am having the exact same issue with mine, so frustrating I’ve only had my Versa for a few months
Hi there @Melli88, welcome to the Community Forums. I'm sorry to hear that you're also having this odd behavior with your Versa. I understand why you must be feeling frustrated.
In order to better assist you, please follow the tips and recommendations I've shared here.
Let me know how it goes, I'll be looking forward to hearing from you.
Best AnswerIt has been charging to 100% and I have tryed all the suggestions days ago. Went to bed with it at around 60% and it was flat when I woke up.
