07-08-2019
05:53
11:50
DavideFitbit
07-08-2019
05:53
11:50
DavideFitbit
My Fitbit Versa is not syncing
07-08-2019 06:04
07-08-2019 06:04
The usual things to try when you get syncing issues are:
07-08-2019 06:04
07-08-2019 06:04
07-08-2019 06:20
07-08-2019 06:20
I tried shutting it down it shut down but now it just keeps on shutting down and starting up
07-08-2019 13:33
07-08-2019 13:33
Thank you - mine just stopped syncing as well and this did it - appreciate it!! I do have another related question - I'm at work so I'm on a different WiFi network (still have Bluetooth turned on). Would the different network be effecting the syncing?
07-08-2019 13:36
07-08-2019 13:36
I don't think so. Syncing happens purely over bluetooth between fitbit and app and as long as the app can connect to the internet to reach the fitbit servers it shouldn't care about which wifi it is using.
07-08-2019 13:43
07-08-2019 13:43
Thanks, that's kind of what I thought, but thought I'd check anyway.
