03-31-2022
15:33
10:15
03-31-2022
15:33
10:15
Is there a way to stop my fit bit from counting bumps in the road as I drive? I haven’t walked but 3500 steps today but it shows almost 10100
04-02-2022 10:16 - edited 08-03-2023 12:03
Hi there, @tammylynn2466. Welcome to the Community Forums. Thanks for the details provided in your post about the inconvenience with your Versa. I understand where your concern is coming from.
Please not wrist trackers count steps depending on the movement of your arms. Fitbit has worked hard to make sure that our devices do not pick up false steps or activity recordings while driving. Unless you're driving in a car with a very stiff transmission or on bumpy roads, your device should not give you false readings. Also, if you place it in a surface with something vibrating or if you make hard hand movements. You can learn more about how your Fitbit tracks steps by checking the article: How accurate are Fitbit devices?
However, there are 2 ways you can prevent this from happening while you drive:
1. You can plug your tracker into the charging cable while you are driving -- the Fitbit will not count steps while it is charging.
2. You can log the driving manually by following the steps in this article.
Best Answer04-02-2022 10:16 - edited 08-03-2023 12:03
