09-13-2018
15:00
09:45
AlejandraFitbit
09-13-2018
15:00
09:45
AlejandraFitbit
Hi, I just saw that S9 is now listed as being compatible, but I'm still having syncing problems. Is there something else I can do to try for it to work? I have:
09-14-2018 01:27
09-14-2018 01:27
@Worbie iveoved your sync issue question out of the notification issue thread. Feel free to edit the title.
I suggest to look at one of my other posts on this subject.
Best Answer09-14-2018 16:10
09-14-2018 16:10
I've tried them and still it's not working properrly 😕
Best Answer09-17-2018 08:59
09-17-2018 08:59
Hi,
My Versa stopped syncing yesterday. Help!
Karen
Best Answer09-17-2018 09:18 - edited 09-17-2018 09:19
Generally a communications hiccup @kamp60
Opening your bluetooth settings on your mobile and forgetting your Versa and letting it rediscover it normally puts everything right again.
If still not syncing (check by touching the fitbit screen and pulling down, or up with windows mobile) then a deeper dive is necessary:
Try restarting your phone (push side button until you get a slide to turn off dialog) and then restarting your tracker:
Press and hold the back (left) and bottom buttons until you see the Fitbit logo on the screen. May take 10-15 secs so hang on, now let go of the buttons.
Turn your mobile back on and launch the fitbit App, pull down to sync. Syncing?
If it's still refusing a sync after there are some more ideas to try in this help file: https://help.fitbit.com/articles/en_US/Help_article/1866/
WmChapman | TX
Ionic, Versa, Blaze, Surge, Charge 2, 3 SE, AltaHR, Flex2, Ace, Aria, iPhoneXR "Every fitbit counts"
Be sure to visit Fitbit help if more help is needed.
09:46
15:27
09-17-2018
09:46
15:27
Hey @Worbie, it's great to see you around and @Rich_Laue thanks for stopping by.
I appreciate all the efforts in trying to fix this issue and recommend taking a look at the help article Why won't my Fitbit device sync? and follow the instructions provide there. Also, make sure to have your location and Bluetooth on at the moment of syncing.
Let me know the outcome. ![]()
14:11
15:27
09-17-2018
14:11
15:27
Hello @kamp60 @wmchapman, thanks for visiting the Fitbit Community.
I moved your posts to this thread in order to keep the Community organized.
@wmchapman Thanks for your help.
If you need further assistance, please let us know.
