05-07-2018
14:52
08:01
AlvaroFitbit
05-07-2018
14:52
08:01
AlvaroFitbit
I have noticed the Versa doesn't always capture all my steps when I do my workout in the pool? I specifically purchased the Versa because it was waterproof and for the reason I workout in the pool. This would be a great feature for the Versa because not everyone is a swimmer or can walk on land.
05-09-2018 08:29
05-09-2018 08:29
@Vermontmaid It's great to see that you've visited the Fitbit Community! Your Fitbit Versa has a 3-axis accelerometer to detect your arm movement and this is translated to steps. Since you are in the water your arm won't be moving as you normally would in land so steps may not be counted. The best thing to do is manually logging your activity but this is to have a better caloric burn calculation so it can be added to your account, it won't necessarily give you steps as this isn't a normal walking activity.
Let me know how it goes!
05-09-2018 10:51
05-09-2018 10:51
I understand what you mean by manually entering my pool time, but I certainly can't take my phone with me to the pool is there a way to do this from the Versa? I am really confused I got the Versa to make this easy and it just seems to be making things more complicated for me now getting frustrated.
05-09-2018 12:06
05-09-2018 12:06
@Vermontmaid wrote:I understand what you mean by manually entering my pool time, but I certainly can't take my phone with me to the pool is there a way to do this from the Versa? I am really confused I got the Versa to make this easy and it just seems to be making things more complicated for me now getting frustrated.
Try this:
Use the upper right button to enter exercise mode. Swipe until you see "Swim" and press on the watch face. Then press the "play" button to start tracking your exercise. When you are done, touch the "pause" button. Then to completely stop the activity I think you have to swipe or maybe press the back button. That should at least log the activity and time (eg, swim 30 minutes).
05-09-2018 12:24
05-09-2018 12:24
I noticed that as well when I was in Jamaica, both in the pool and the ocean. It did recognized Swim activity correctly!
@Vermontmaid wrote:I have noticed the Versa doesn't always capture all my steps when I do my workout in the pool? I specifically purchased the Versa because it was waterproof and for the reason I workout in the pool. This would be a great feature for the Versa because not everyone is a swimmer or can walk on land.
Best Answer05-09-2018 13:59
05-09-2018 13:59
Thank you for your suggestion but I am not swimming. I am doing a walking PT program to rehab a bad knee.
Best Answer05-09-2018 14:05
05-09-2018 14:05
It is not going to count your steps in the pool no matter what you do.
Please read @AlvaroFitbit post. Your arms are not moving correctly in the pool to count as steps
When I wanted the steps counted when I was doing PT like you I would manually add Steps by figuring out the length of the pool and how many steps per lap.
Just be aware manually logged steps do not go towards badges or challenges
Wendy | CA | Moto G6 Android
05-09-2018 14:24
05-09-2018 14:24
I understand it won’t count my steps in the water I really do get that, but what I don’t understand is how the heck to manually enter what I am doing. The instructions are about as clear as mud to me. This was supposed to be simple and fun. So far all I have had is frustration and aggravation clearly I am not a technical person.
Best Answer05-10-2018 09:34 - edited 05-10-2018 09:35
Here is info about manually logging exercise depending on whether you are doing it from your computer or your mobile device:
https://help.fitbit.com/articles/en_US/Help_article/1144/?q=track+exercise&l=en_US&fs=Search&pn=1
I am not sure if you can log exercise directly from the versa. The closest I can find is what I mentioned above, about using the "exercise" app to record the length of time you are doing that exercise.
If the instructions in the above link are not clear, let us know which method you are using (iPhone app, Android app, computer, etc) and maybe we can provide some better instructions.
Best Answer06-19-2018 11:46
06-19-2018 11:46
I am having the same issue in the pool. Today I made sure to move my arms in the water and after an hour I only had 26 steps. This is disappointing. I could manually log swmming with my Alta and would not have spent this much money on a new fitbit. My old Garmin vivofit worked well in the water as long as you were moving your arms but the battery only lasts a year.
The Versa is a disappointment for us water lovers.
06-19-2018 12:06
06-19-2018 12:06
Best Answer06-19-2018 14:03
06-19-2018 14:03
Best Answer06-19-2018 15:54
06-19-2018 15:54
Best Answer07-11-2018 11:56
07-11-2018 11:56
I was going to replace my AltaHR with a Versa because I do water aerobics with running and walking in the pool and plenty of arm movement. We have a steps challenge at work, and I assumed the Versa would give me steps for this. I'm reading that it won't is that correct? I wonder why a Garmin tracker is easily used in the pool and steps are tracked and Fitbits are not?
07-11-2018 12:16
07-11-2018 12:16
Best Answer07-11-2018 19:50
07-11-2018 19:50
Thanks for the info. If I set it to swim it isn’t going to count as steps for our work challenges so I don’t want t to spend the $$ if I get the same results as my Alta without taking it in water.
Best Answer07-11-2018 19:51
07-12-2018 11:03
07-12-2018 11:03
01-03-2019 03:08
01-03-2019 03:08
I turned on treadmill exercise while walking in the pool. Gave me steps and exercise. Not sure if it gave me all my steps i use floatation weights and move my arms a lot.
Best Answer02-25-2019 14:01
02-25-2019 14:01
Same issue. My husband bought this specifically for its waterproof characteristics and has been a huge disappointment particularly when other women I exercise with water walking who have Garmin units do not have this issue. Fitbit needs to come up with a solution otherwise this is an expensive toy.
That said, I did find my steps on a treadmill which I have never had it on so we shall see tomorrow what comes up on that.
It should not be necessary to use this.
