Hi @Meliha , if your touch screen is still working: settings - device info - press that and scroll down to either "shutdown" (and do that several times) or "Factory Reset" if you really want to do a reset. Before doing that, sync your Versa with your phone so you will not loose any data. Regards kuzibri
Best AnswerIf your left button isn't working and the touch screen also doesn't work, I would call Customer Support. might be a hardware problem. Regards kuzibri
