I haven't used my versa lite in a really long time, and when I put it on charge, it just goes to the Fitbit logo screen, but it never charges? I left it for around 6 hours and it still won't turn on either.
Hi @Kbacol - was the reason you weren't using the watch because of this problem of logo screen?
If you haven't used or charged it for 6 months the battery would be flat, the fact that it can show the logo screen means it has charged, at least to some extent, so charging is not the problem.
You can always try this procedure Versa 2 stuck on Fitbit Logo posted by @MarreFitbit
If that doesn't work probably best to contact Fitbit Support directly. They may be able to help you.
Also reachable via the Fitbit App, click profile photo, Help & Support, Contact Customer Support.
