01-09-2021 18:13
01-09-2021 18:13
My versa lite is not getting any notifications. Anyone else?
Best Answer01-10-2021 01:01
01-10-2021 01:01
Hi, was it working until recently?
try rebooting the watch and phone
Logout of Fitbit app [click profile photo, top left, scroll to bottom] Shut down watch [ Swipe left, Settings, at the bottom, About, at the bottom, Shutdown]
Best Answer01-10-2021 08:54
01-10-2021 08:54
Best Answer01-10-2021 10:28
01-10-2021 10:28
Ah, your new phone is the reason!
Suggest you do the installation on the new phone - Check setup procedure
Also check your phone is on the compatible phone list. Just in case.
Best Answer01-10-2021 13:13
01-10-2021 13:13
Best Answer01-10-2021 21:46
01-10-2021 21:46
@KaamoldI believe not being on the compatibility list means it has not been verified.It may work but as every phone is different its functionality cannot be assured.
You can check
In the phone Fitbit App Click on profile photo [top left]
Device photo [middle left] Sync - See when last synced Try refresh by touching circle it should say "a moment ago" |
Device photo [middle left] Notifications And verify the top 4 items are correctly defined.
And App Notifications Tick any other apps you wish to hear from
NB. Notifications have to appear on the phone which has to be in contact with the watch for them to appear on the watch. Deleting them on the phone removes them from the watch, and vica versa.
If you missed seeing a notification on the watch, swipe down from the top edge and they will show [or be all caught up]
