08-27-2019 12:44 - last edited on 08-28-2019 15:12 by LiliyaFitbit
I can view my texts/messages on my versa lite, but I've never seen the option to reply. I went to the fitbit app on my phone and turned on notifications and selected the apps I have that I would like to see notifications from. I clicked on quick replies, selected my texting app, and then customized the messages I would like to have as a quick reply.
I'm curious, I went to https://www.fitbit.com/devices# to check to see if my phone was compatible with fitbit, which I thought it must be, since I've been using it for a while and except for the quick reply feature, everything else is fine. When I typed in LG G4, the website said the device was not found...
Any thoughts?
Best AnswerWelcome to the Fitbit Community, @AmberMei.
I appreciate your participation in the Forums and sharing your concern regarding the quick replies feature for your Fitbit Versa Lite. Thank you for your efforts to resolve the issue and sharing that you're using an Android LG G4 phone and can view your texts and messages on your watch. While your phone is not a supported device for the Fitbit app at this moment, it doesn't mean that it won't work with the app entirely, but rather that some of its functions might work intermittently.
The quick replies feature is currently available on devices paired to an Android phone (7.0+). I recommend checking the following help article where you can confirm the steps to setup and use quick replies: How do I respond to messages with my Fitbit device?
Best AnswerThank you so much!
My phone only has Android 6 and I don't see any updates available. At least now I know why the feature didn't work.
Thanks for the help!
Hi @AmberMei, thank you for your reply.
I appreciate your efforts and the additional details. Thank you for your time and feedback! I am glad to hear the information provided was helpful.
Feel free to explore the discussions forums to Share Your Story, Get Fitter, Find wonderful Fitbit Friends, Sharing Recipes and much more.
Keep on visiting the forums! ![]()
Best AnswerHi LiliyaFitbit, I have 2 other questions:
You said my "phone is not a supported device for the Fitbit app at this moment" - does that mean it might be later?
My second question is probably kind of silly, but is there any way that the quick replies could be made to be compatible with Android 6? It would be really snazzy if that feature could work with older android systems.
Thank you!
Best AnswerHi @LiliyaFitbit ,
Just following up:
Thank you!
