12-05-2019 07:27
12-05-2019 07:27
The last 3 days my versa is loosing time( about 30 mins a day). I've reset it 3 times, with no luck. It does fix time when it syncs. I have all day sync on.
12-05-2019 10:12
12-05-2019 10:12
A reset normally called a soft restart. Or did you do a complete power down of the Versa.
Only a compiler power off will fix a hardware lock up issue.
12-05-2019 11:11
12-05-2019 11:11
12-05-2019 12:33
12-05-2019 12:33
I've had the same issue for months now. I've shut it down, changed the face and did a factory reset. It only works when its fully charged.
