02-18-2019 06:35
02-18-2019 06:35
Versa loses a minute every few days.
Does not correct with synching.
Tried rebooting.
Uninstalled and reinstalled app on phone.
Software up to date.
Using a fitbit clock face.
Phone is Samsung Galaxy S9.
02-18-2019 15:58 - edited 03-03-2019 09:14
@Syvret It's losing time because it is not syncing properly. Try restoring bluetooth connectivity:
The trick here is to not pair in phone Bluetooth settings but rather let the Fitbit mobile app do that.
Additional tips if sync issues persist: If you have Wifi set up, go to Fitbit mobile app and remove it, then sync your Versa. I noticed that it causes issues for me. If you have other Bluetooth devices paired with your phone, forget them. One of them might be causing issues. Also, make sure Always Connected and All day sync are enabled.
If this does not help, try performing a factory reset (restoring your tracker to factory defaults). This will wipe your Versa, so please sync first if possible. You will also need to delete your tracker from your Paired Devices list in your phone Bluetooth settings. You can perform factory reset by going to Settings on your Versa, scrolling down to About and tapping Factory Reset. Once Versa resets to factory defaults, you will need to set it up again by adding it as a replacement device in the Fitbit mobile app.
02-21-2019 06:01
02-21-2019 06:01
Having same issue last few days and I’ve tried all of these steps! Nothing helping so I think FitBit needs to do an update or something because it seems to be happening to a lot of people! Just overnight it lost 45 minutes. But for the last six months it had been working perfectly!
02-21-2019 12:47
02-21-2019 12:47
@SunsetRunner phone model and OS? Versa firmware version and Fitbit mobile app version? When exactly was your last sync? Please open Fitbit mobile app, tap on the Versa icon and scroll down to the sync section. What's the time stamp there?
02-21-2019 12:59
02-21-2019 12:59
IPhone 7 Plus, oiS 12.1.4
fitbit version 2.88 as of 2 days ago which is when problems started!
Can’t give you last sync right now (but I was syncing several times a day) because I just removed everything from my phone and am going to try a factory reset and reinstall tonight. If that doesn’t fix it i don’t know what else to try! Thanks!
02-21-2019 13:04 - edited 02-21-2019 13:05
@SunsetRunner Please go to your Dashboard on Fitbit.com and click on the Settings icon (gear cog) in the top right corner. You should the last sync there.
ETA: If pairing and unpairing of the tracker does not work, I probably would try factory reset as well. Good luck!
02-21-2019 13:13
02-21-2019 13:13
Looks like last sync was 4 hours ago, but I “removed” the versa from my FitBit account right around that time. Fingers crossed that the factory reset helps! Thanks for troubleshooting with me.
02-21-2019 13:17
02-21-2019 15:14
02-21-2019 15:14
I just noticed mine doing this earlier today. It was two minutes off an hour ago, and now is five minutes off. I cannot keep having all of these issues with this watch! I refuse to do a factory reset again, as it takes hours to put all of my music back on it. Between the outrageously high floor count (goes up when I am dancing around on the same floor), the problems syncing and now this, I am planning on getting rid of the Versa. I've had a Fitbit for years, back when people would ask, "What is that? What does it do?" and this is ridiculous that Fitbit has such a terrible product out there after so many years of being in the business.
03-01-2019 10:34
03-01-2019 10:34
@Syvret @SunsetRunner did you manage to resolve the issue?
03-01-2019 10:43
03-01-2019 10:43
Unfortunately not. It’s been a constant source of frustration for over a week now. I keep hoping FitBit will put out an update that will fix this since it seems to be happening to a lot of people in reading the forums!
03-02-2019 09:02
03-02-2019 09:02
@SunsetRunner Yes, this seems to be related to the recent update. hmmm Factory reset didn't resolve the issue? it seems to be losing bluetooth connectivity and thus can't sync properly (loses time). Have you tried syncing it with other device? Sometimes when my Versa would get stuck, I would sync it with my other phone, and for whatever reason it would resume sync as usual with my main device... O.o
03-02-2019 09:22
03-02-2019 09:22
Hi. Yes, I Think I’ve tried everything humanly possible, including a factory reset and trying to connect it to my iPad instead of my iPhone. Nothing is helping. It will randomly all of a sudden sync and then over the next several hours continually lose time. It’d be nice if FitBit at least told people that they’re working on this problem, but I haven’t seen any kind of acknowledgement that they’re aware of this issue. I’m wondering if it’s time to just buy an Apple Watch but my Versa is less than six months old!
03-02-2019 09:24
03-02-2019 09:24
@SunsetRunner Something else is bothering me. If it syncs at least once a day or so, it should not lose time that quickly. It just shouldn't. I think you should reach out to Customer Support. Factory reset did not resolve the issue either, I'm afraid something else might be wrong here.
03-02-2019 09:28
03-02-2019 09:28
One of the FitBit moderators told me they put in a service ticket and that someone would be in touch with me. That was on February 28, no word yet!
03-03-2019 06:27
03-03-2019 06:27
03-03-2019 09:16
03-03-2019 09:16
@Syvret Yes, I am not surprised. I have seen reports from people whose battery got back to normal after performing factory resets. This seems to be some firmware bug, IMHO. Other thing to keep in mind is 3rd party clock faces. Some of them, especially those stats heavy with frequent refresh rate, can cause a substantial battery drain - even 50% more.
03-14-2019 23:14
03-14-2019 23:14
I am so with you on this, it shouldn't take this much effort and conversation to get an electronic watch to work. Just today mine has lost 25 minutes over the course of the day, It's 3 months old. It was working fine until about 5 days ago, and now I seem to have to choose between having a step counter or a watch. I am so keen to hear if you've found a solution. Everyone here looks like they've tried everything as have you!
03-15-2019 07:17
03-15-2019 07:17
Hi. My eventual solution was to buy an Apple Watch! I fought with my Versa for three weeks and nothing I did solved the issue. I was told 2 weeks ago that someone from customer service would be in touch with me, and I never heard a word. I can’t believe what horrible service they’re providing to folks who paid good money for their Versas. It’s clearly a software/firmware problem since it’s affecting so many, yet they aren’t even acknowledging that there’s a problem.So, I’ve given up on FitBit.
03-25-2019 23:50
03-25-2019 23:50
So sick of this when is someone going to fix it. You’re losing customers Fitbit
