01-13-2020
12:20
11:31
DavideFitbit
01-13-2020
12:20
11:31
DavideFitbit
Hi
The screen on my Fitbit Versa has gone off and there are no green lights on back
I only got it on Saturday as replacement for previous one which had same problem any help
01-13-2020 12:43
01-13-2020 12:43
If that does not work try A Long Restart
Plug the device into the charging cable. While the device is plugged into the charging cable, hold the button down for 15 seconds. Remove your finger from button. Note: Device won't have a smiley face icon and should be off with a black screen. Remove the device from the charging cable. Plug the device into the charging cable again. The smiley face icon appears on the screen.
If it does not help contact support. Use the Help link at the top of the forum
Wendy | CA | Moto G6 Android
