07-08-2019
19:45
11:48
DavideFitbit
07-08-2019
19:45
11:48
DavideFitbit
My Versa is a year old. Over the past 2 weeks I can not get it to hold a ch as the for 24 hours. I place it on the charger each night, in the morning it is at 100%. However, by 9 it is only at 8%. How can I improve the charge it holds?
Moderator edit: format
07-08-2019 23:37 - edited 07-08-2019 23:38
Hi @JillMarie30 Try restarting it several times amd see if that improves the battery life. If it doesnt all you can do is to try a factory reset (settings app and scroll down to About). Good luck.
Helen | Western Australia
