09-06-2019
06:13
05:28
JuanJoFitbit
09-06-2019
06:13
05:28
JuanJoFitbit
my versa has stopped receiving notifications. I’ve restarted it and it syncs with my iPhone just fine. However when I go into the app to make sure my notifications are turned on I get a message saying that it can’t find the device... despite the fact that it’s syncing ok! I’ve already done a factory reset this week for the wake feature. I don’t want this to have to be a regular procedure. I never had these problems with my Blaze and am starting to regret “upgrading”.
09-07-2019 05:28
09-07-2019 05:28
@Kendell1 it's great to see you in our Fitbit Community! I'm happy to assist you with your Fitbit Versa since it's not getting notifications from your phone. By the way, thank you for troubleshooting this issue before contacting our forums.
I'd like you to try the troubleshooting steps that are listed in this help article. After trying these steps, monitor your Versa and see if it gets notifications properly.
Keep me posted on the outcome! 😀
Best Answer09-07-2019 05:28
09-07-2019 05:28
Best Answer09-08-2019 06:26
09-08-2019 06:26
Best Answer09-08-2019 10:30
09-08-2019 10:30
I'm not getting any notifications at all. This is not the first time it's happened and I'm slightly annoyed at the fact that it keeps happening. Support is not helpful.
09-10-2019 03:25
09-10-2019 03:25
Yes support is not being helpful at all. They keep sending me the same steps to try. I’ve even done a factory reset. I’ve only had the Versa for 4 months... this shouldn’t be happening. Guess i’ll Have to call.
Best Answer09-10-2019 03:27
09-10-2019 03:27
Sorry, did not mean to select the accepted solution! My notifications are still not working!
