I had a versa and it stopped working and have since received a replacement however I am not consistently receiving text notifications. I works some times but I would say a majority of the time it doe not. I have turned my Bluetooth on and off. Re synced my versa with my phone through the app but nothing is working. I so want to love my Fitbit and stick with this company but I am thinking of just getting an Apple Watch. It’s been less than a year and I’ve has more than a few issues with the versa 🤨
Hi, since this seems to be a Fitbit app problem, I would suggest the following:
1. Before following the suggestions do not remove or unpair your Versa from the Fitbit app
2. Deinstall the Fitbit app
3. Restart your mobile device and after that wait for a few secs.
4. Reinstall the Fitbit app and, of course, enable BT.
5. Sync your Versa with the Fitbit app and see if the problem is solved.
Good luck!!
13:24
11:19
03-22-2019
13:24
11:19
Welcome to the Community @Penntigger and @SunsetRunner thanks for the input.
I was able to see here that our friend @SunsetRunner provided some instructions in order to fix this notifications issue. Was this the answer you were looking for? If it was, I recommend marking the answer given as a solution. By doing this, other users with the same inquiry will be able to find a faster response.
Now if your inquiry/issue wasn’t resolved, let me know and I will be glad to help you out. ![]()
