06-12-2018
08:50
12:24
AlvaroFitbit
06-12-2018
08:50
12:24
AlvaroFitbit
Even after charging versa is not starting..I have tried pressing left and right bottom button but there is no response
Please help
06-12-2018
10:19
12:25
AlvaroFitbit
06-12-2018
10:19
12:25
AlvaroFitbit
Time to contact Customer Support.
06-20-2018 12:29
06-20-2018 12:29
@Neharai Welcome! Thanks for being part of our Community! Sorry to hear that your Versa isn't working. Please try cleaning your Versa contacts with a toothpick or toothbrush and then use cotton with rubbing alcohol. Try restarting your watch by doing the following:
1.- Press and hold the back (left) and bottom buttons until you see the Fitbit logo on the screen. This should take less than 10 seconds.
2.- Let go of the buttons.
3.- If your Fitbit watch doesn't work normally, use the instructions in How do I turn off my Fitbit device? to turn your watch off and on again.
Now plug it for a couple of hours and see if it responds.
Also as @SunsetRunner said you can contact our Support team for further assistance. I noticed that you already have a ticket with them so I wanted to know what did they tell you?
I look forward to your reply!
04-17-2019 03:41
04-17-2019 03:41
we are child learning India has launched one education application that is parent teacher app. its help you to communicate with teacher by sitting at home. there are so many features available in this application for more you can follow our website.
