08-20-2018
16:55
05:39
AlejandraFitbit
08-20-2018
16:55
05:39
AlejandraFitbit
Super frustrated after having no issues for months on my Versa. Now all of a sudden for last few weeks I receive no vibration alert for texts and emails. Calls and test calls are the only thing that go through, no other apps work either. Yes, I am aware of the quick setting and the other vibration setting. App up to date on Samsung Galaxy S7 Edge. Reset Versa, Bluetooth, app, phone. Tried everything. I get alerts to Versa, I just don’t know they are there unless I swipe up.
08-29-2019 13:12
08-29-2019 13:12
Best Answer08-29-2019 13:24
08-29-2019 13:24
08-29-2019 14:05
08-29-2019 14:05
That is the correct process to get notifications turned back on. Are you asking a question about that process, or reposting the solution for others? Sorry if I am being thick.
Best Answer08-30-2019 07:23
08-30-2019 07:23
Just replying,.new this group
Best Answer09-01-2019 11:18
09-01-2019 11:18
YES! thank you!
Best Answer09-01-2019 17:05
09-01-2019 17:05
Best Answer09-04-2019 14:42
09-04-2019 14:42
That worked! Thank you so much! I was stumped. I had tried everything else. I got a new phone and it threw everything off. YOU ROCK.
Best Answer09-05-2019 03:10
09-05-2019 03:10
Thank you. Very happy to help. That is a very frustrating problem.
Best Answer09-09-2019 16:25
09-09-2019 16:25
THANK YOU THANK YOU THANK YOU!!!
Best Answer09-09-2019 23:57
09-09-2019 23:57
Best Answer10-05-2019 10:08
10-05-2019 10:08
THANK YOU! That was my issue and I couldn’t figure it out!
Best Answer12-13-2019 04:20
12-13-2019 04:20
Where to find the notifications switch?
Press and hold the left button and i get all my notifications. It drops down a quick setting menu from top, but no notifications settings.
Too bad we're can't post pictures in this community.
Please help...
version 32.70.7.14
Best Answer12-18-2019 17:39
12-18-2019 17:39
Fantastic easy solution for a very frustrating problem... holding the Back button and seeing that Notifications were turned off. Thank you!
Best Answer12-18-2019 17:47
12-18-2019 17:47
Best Answer12-30-2019 22:21
12-30-2019 22:21
My Versa vibrates for all other notifications and phone calls EXCEPT text messages. I've literally tried everything, and I am getting pretty frustrated. I do not remember the exact instance when the vibrations stopped for the texts, but I'm wondering if it has something to do with the latest update?
12-31-2019 12:23
12-31-2019 12:23
Best Answer01-01-2020 13:48
01-01-2020 13:48
I have exactly the same problem. Even after factory reset. All notifications work, including the test notification, but emails and texts do not vibrate - they appear on the Versa but no vibration and no obvious indication, unless I pull down to see them.
Best Answer01-07-2020 22:45
01-07-2020 22:45
Versa not vibrating for text and calls even I set on for all notification
Best Answer01-07-2020 22:48
01-07-2020 22:48
Did you try my fix via quick settings on the Versa? That is the key step.
Best Answer04-03-2020 15:11
04-03-2020 15:11
When i hold down my left button, it only gives me the options for do not disturb, sleep mode, and brightness... i dont have an option for notifcations.... Sleep mode and do not disturb are all off. i have been doing all of the fitbit notification trouble shooting steps all day... finally got texts to come back and appear when i pull them down, but no vibration/notification
