08-20-2018
16:55
05:39
AlejandraFitbit
08-20-2018
16:55
05:39
AlejandraFitbit
Super frustrated after having no issues for months on my Versa. Now all of a sudden for last few weeks I receive no vibration alert for texts and emails. Calls and test calls are the only thing that go through, no other apps work either. Yes, I am aware of the quick setting and the other vibration setting. App up to date on Samsung Galaxy S7 Edge. Reset Versa, Bluetooth, app, phone. Tried everything. I get alerts to Versa, I just don’t know they are there unless I swipe up.
08-22-2018
05:40
04:30
08-22-2018
05:40
04:30
It's great to see you around @jsalvaggio.
Thanks for troubleshooting this by yourself. Can you please tell me which troubleshoot have you tried so far? In the meantime, I recommend restarting your Versa by doing the following:
Let me know the outcome. ![]()
08-23-2018 12:02
08-23-2018 12:02
I have restarted both phone and Versa several times. Uninstalled app, reinstalled and set all notifications back on, reset Bluetooth, checked all the notifications to make sure they are on Versa and phone app for email and text. Using default text and email applications that were working just fine for last few months.
I am getting the emails and texts to the Versa, it's just not vibrating to alert me. So that tells me it's not anything with the connection, sync or phone. Its a bug with the Versa. Phone calls will vibrate still.
11-17-2018 11:40
11-17-2018 11:40
I had this issue to and I went to setting on the versa and notification was on! Then I went to the Fitbit troubleshoot site and you have to hold the left button until it shows the quick menu, it showed that my notifications were actually off.
Here is the site to help with other small things you might have missed 👍
https://help.fitbit.com/articles/en_US/Help_article/1979?p=versa#choices
11-17-2018 13:06
11-17-2018 13:06
I just got mine and after a week it stopped vibrating for messages but continued to vibrate for it's own stuff. I finally got it straightened out by fiddling with settings. I think there was an update that took it off vibrate. It took me a few days to figure it all out and get it going again and I don't really remember now just exactly where thee setting was that had been turned off but it was not a quick find for me. Once I did find it and reset it, it's been working fine again.
Best Answer03-08-2019 16:35
03-08-2019 16:35
The quick menu solution worked! Excellent. Thank you.
03-13-2019 17:40
03-13-2019 17:40
Easy fix!
Simply press and hold the back button until the "screen wake" or "music controls" screen pops up and press "notifications" to ON.
This accidentally gets pressed and turned off sometimes! Same issue happens periodically to me.
03-25-2019 08:29
03-25-2019 08:29
Thanks you. That fixed it.
03-27-2019 14:20
03-27-2019 14:20
Thank you, that was my issue!
04-17-2019 16:22
04-17-2019 16:22
I just figured this out! If youre in the Fitbit app settings and you select the Fitbit app under "Manage App Notifications," it will interfere and not vibrate even for a test call, much less any other notification.
Go into "Manage App Notifications," and uncheck the box next to "Fitbit."
Allow ~30 seconds to let that sink in, and then try the test call.
Hopefully that helps!!!
04-18-2019 00:44
04-18-2019 00:44
Same issues on ios Apple,but never get emails
04-18-2019 04:51
04-18-2019 04:51
this was exactly the issue with mine!!
thank you for sharing
04-18-2019 10:31
04-18-2019 10:31
Mine doing this issues just recently after doing reset last week. Still never fixed, then flyer headset is dead refused to be seen it say cannot find device, tried AirPods also failed, you have same issues?
04-18-2019 15:12
04-18-2019 15:12
With Fitbit phone support got it to work, these folks are true professionals , but thanks for you sharing and help
05-25-2019 16:52
05-25-2019 16:52
This worked well. Its frustrating to figure this out.
05-25-2019 21:16
05-25-2019 21:16
06-01-2019 20:16
06-01-2019 20:16
Thank you for your insight and info, I checked my notifications and mine were off, as well. They probably got turned off while I was changing the band.....👍😀
06-01-2019 21:39
06-01-2019 21:39
06-14-2019 19:56
06-14-2019 19:56
Thank you, that resolved my issue!
06-14-2019 20:04
06-14-2019 20:04
