04-14-2020 10:49
04-14-2020 10:49
My versa hasn't been vibrating for notifications for about a month now. I have done a hard reset on the watch, removed it from the app and added it back, deleted the app and added it back and nothing seems to be working.
Any other help would be great!
04-14-2020 11:04
04-14-2020 11:04
@kbkb8 Are you receiving notifications on Versa at all? Is it just the vibration? Try pressing and holding the left button to open a Quick Settings menu and make sure the notifications are enabled there.
Best Answer04-14-2020 18:21
04-14-2020 18:21
Notifications are coming through but not vibrating. Not in sleep or do not disturb mode.
Best Answer04-15-2020 09:08
04-15-2020 09:08
@kbkb8 Have you tried opening Settings app on your Versa, scrolling down to Vibration and toggling between Normal and Strong? Does it vibrate? Have you tried rebooting the tracker?
