06-15-2019 07:27 - last edited on 06-16-2019 15:10 by LiliyaFitbit
My Versa started to not sync, then was not keeping the correct time. I tried resetting it using the two button way. No help. After 3 days of trying, I did a factory reset. Now versa will not turn back on. I also tried to hold down all the buttons for over 3 minutes several times. No luck.
01-19-2020 21:19
01-19-2020 21:19
I strongly suggest that you contact @Fitbitsupport.
01-22-2020 09:32
01-22-2020 09:32
Mine is having the same problem. I have tried to reset it several times, but it doesn't turn back on. What else can I do?
01-22-2020 09:52
01-22-2020 09:52
01-22-2020 10:36
01-22-2020 10:36
01-22-2020 21:10
01-22-2020 21:10
01-30-2020 04:30
01-30-2020 04:30
After latest system update, Versa started to act up and would constantly crash on sync.
Unpaired and re-paired it couple of times but in vain. Finally decided to do factory reset and now even I am stuck with blank screen.
When I did reset, battery was at 84%. Still this thing won't start up.
Tried all solutions mentioned here. None worked for me.
02-01-2020 13:40
02-01-2020 13:40
Yes i have had the excact same problem with my watch and it is very frustrating as i camt turn it on. I would very much appreciate if you could help me and find a solution to this problem..
02-26-2020 13:07
02-26-2020 13:07
I have had the same issue for 2 weeks, Versa wouldn't connect with my phone, did factory reset, and now get black screen. I talked to customer service and they said they will give me 25% off a new one. I don't want a new one just fix the one I bought. I need to know the next step what should I do?
02-26-2020 16:32
02-26-2020 16:32
02-26-2020 17:12
02-26-2020 17:12
Hi, I have done the FR. The device became unresponsive totally.. Tried above mentioned steps already. But no relief. Pls support if you have any customer service centers in India.
02-26-2020 21:49
02-26-2020 21:49
03-19-2020 14:17
03-19-2020 14:17
Help - this has happened to me now . Had syncing issues and battery drained last night - charged, still couldn’t sync or see via Bluetooth- ended up doing factory reset and followed directions to get it to restart - nothing !! Just a black screen! This is frustrating - every Fitbit i get usually ends up having issues once I am out of warranty - time to switch to Apple Watch??
03-19-2020 15:54
03-19-2020 15:54
03-30-2020 06:57
03-30-2020 06:57
I have tried this multiple times but it doesn't work. I have been loyal to fitbit from the inception of the company and I am very disappointed in Fitbit that they know peoplearehavingtroublewith factory resetting their versa devices and it doesn't want to work afterwards... I would replace orrecall the product because all Fitbit is doing now is destroying their brand reputation.
03-31-2020 02:24
03-31-2020 02:24
My Versa is 16 mths old, my wife and kids bought me a Fitbit because I have heart problems. I could not get debit card to load on Versa, all related data was on my phone Versa app but just wouldnt load to phone. Tried different things and eventually did a factory reset by using the Versa's settings menu and Factory Reset with a Yes.
Since then black screen and nothing, tried left and bottom right buttons but nothing. Had 40% charge when I did factory reset, have tried to charge but nothing shows up, no flashing lights on back, Nothing. 16 months and it seems stuffed. HELP plse, I need this for my heart problems.
03-31-2020 02:27
03-31-2020 02:27
03-31-2020 17:05
03-31-2020 17:05
Was your Fitbit still under warranty? How did they help you?
04-13-2020 14:39
04-13-2020 14:39
I am experiencing the same issues. I tried all the steps mentioned. Still no display.
04-18-2020 10:25
04-18-2020 10:25
I’m having the exact same issues, can anyone help me?
04-18-2020 11:25
04-18-2020 11:25
