05-15-2018 14:03
05-15-2018 14:03
I have new Versa and Sony Z5 Android 7.1.1 (all updated, restarted, enabled,..). All my notifications are delayed (1-8 seconds) or sometimes even missing.
Even if I try "Send a Test Call Notification" from Notification menu it takes 1-5 seconds.
Is it normal ? How long should it take?
Thanks,
Tomas
Best Answer09-15-2018 15:37
09-15-2018 15:37
I've changed the phone from Sony Z5 to Motorola Moto g6 Plus and all the sync problems are gone.
Best Answer05-15-2018 14:21
05-15-2018 14:21
Mine has a slight delay also. I think it’s normal. I’m just happy I received them lol.
Best Answer05-17-2018 08:03
05-17-2018 08:03
I'm Ok with dellay in message notification, but not in case of calls... I'm already talking when versa got the notification.. Is it normal?
Best Answer07-15-2018 12:31
07-15-2018 12:31
I am also having the same problem. Delay of a seconds and sometimes the test call times out and thus is never received on phone.
I have seen that this problem is related to sync. Every time I make a test call the phone tries to sync with the device and because of that whole sync is ongoing the call or other notifications are not sent. The moment the sync is complete the notification is received.
Why is the sync taking so long and can I disable it or reduce the frequency. Thanks
09-15-2018 15:37
