Over the weekend I was busy and didn't have time to charge my watch, but when I got to work I plugged it into the wall, verified it was charging, and left it alone for several hours because I forgot about it, then I got a notification from Fitbit saying my Versa had a low battery, so I went back to my desk to discover it in fact stopped charging at around even though it was still on the charger. I tried taking it off the charger and resetting it, and still it would not charge. Moved outlets after trying 3 different ones it finally starting charging again and then after about 10 mins it stopped again. So on my way home I plugged it into my car charger to see if would at least charge a little bit more, it got up to 62 percent but now again will not charge. I got the watch in January so I haven't even had it for 6 months, I don't get it wet and I keep it quite clean so this is just ridiculous. It's syncing fine to my iPhone 8plus, in fact that's the only way I found out it wasn't charging.
Hi, normally I would advice the restarting procedure, but as I think it's a harware issue, contact Customer Support and asl for a battery test.
@J93 The first thing support will tell you is to restart your tracker
So please restart before contacting them
Wendy | CA | Moto G6 Android
@J93 I'm sorry for the late response. However, let me give you a warm welcome to the Fitbit Community!
Regarding the charging issues that your Versa is experiencing, I was able to get in touch with our Support team and was told that they contacted you via email. Please check out your email account and they'll be happy to follow up.
Thank you so much for your help guys @SunsetRunner @WendyB!
I'll be around if you have any doubts! 😀
