04-29-2018
17:06
05:56
AlvaroFitbit
04-29-2018
17:06
05:56
AlvaroFitbit
I have had my Fitbit Versa just over two weeks and in that two weeks, it has failed to alarm twice. This morning it alarmed at a time I didn't have set for it to alarm. This is my only major complaint. Anyone else having the same issue? I have set both of these alarms local on the device and not via an app or anything.
05-06-2018 06:18 - edited 05-17-2018 10:16
@aroyrichardson @Accupulse @Sim877654 @picaroo Welcome to the Fitbit Community! I hope you're doing well! I suggest you restart your Versa to see if this helps resolve the issue. Please try the following:
1.- Press and hold the back (left) and bottom buttons until you see the Fitbit logo on the screen. This should take less than 10 seconds.
2.- Let go of the buttons.
3.- If your Fitbit watch doesn't work normally, use the instructions in How do I turn off my Fitbit device? to turn your watch off and on again.
Also try removing all the alarms, restart your Versa and set the alarms again. One last thing to do is Factory Reset your Versa by going to settings > about and set the alarms again (note that you will need to setup your Versa again with this process).
Let me know how it goes!
05-02-2018 03:41
05-02-2018 03:41
Im having the same issue. I have an alarm set for 6:20am and some help mornings it works ans some morn6it doesn't.
05-03-2018 15:02
05-03-2018 15:02
Same problem here. Very inconsistent, sometimes it goes off at the correct time, sometimes at a random time and sometimes not at all!
05-04-2018
00:23
05:56
AlvaroFitbit
05-04-2018
00:23
05:56
AlvaroFitbit
same here not good ...
05-10-2018 09:01
05-10-2018 09:01
Can you please clarify what "the button" is? Thanks.
05-10-2018 16:03
05-10-2018 16:03
I’ve had this issue as well, restart didn’t fix, deleting all alarms and re creating worked for a week or so but today all alarms haven’t worked again. Very frustrating when you wake up an hour after u where meant to be awake!!
05-10-2018 16:08
05-10-2018 16:08
05-21-2018 19:04
05-21-2018 19:04
I tried resetting and everything and tested out the alarm! It only vibrates about 3 times then stopped 😞 no way is this gonna make me wake up! I had no issues with my charge 2! Is there any way to make the alarm vibrate for longer? I’ve already put it on strong
05-21-2018 19:31
05-21-2018 19:31
We really need a way to extend the alarm duration. My Pebble watch alarm was way better than this one.
05-23-2018 08:21
05-23-2018 08:21
@rdunbaredge @Usernameme @Annamei @MWKrieger Welcome! Thanks for being part of our Community!
@rdunbaredge sorry about the mishap I have corrected the instructions so you can restart your Versa.
@Usernameme sorry to hear that this didn't work for long. You could try Factory resetting your Versa (go to settings > about > Factory Reset) and setup your Versa again after that.
@Accupulse not sure how the security pin could affect your alarms but thank you for sharing this tip with all of us.
@Annamei @MWKrieger currently this is the way it works but you can vote for the idea of improving the alarm in our Feature suggestions board. The more votes an idea gets the more likely the developers will try to implement it.
Keep me posted!
05-24-2018 12:59
05-24-2018 12:59
after updating the device to 32.32.10.15 I've not had a problem with the alarm not going off when it should 😄
05-27-2018 06:20
05-27-2018 06:20
@Sim877654 thank you for that update. It does help to know that with the latest firmware your Versa is working as it should. Hopefully this will help other members in the same situation!
I'll be around!
06-06-2018 07:07
06-06-2018 07:07
The suggested "fix" does not work. It is really disappointing to not be able to rely on an alarm after spending hundreds of dollars on the device.
06-07-2018 11:36
06-07-2018 11:36
I have now had the Versa alarm fail on me three times. I missed my cycle class at the gym this morning BECAUSE of my Fitbit which seems a little ironic!! I have the limited edition version which set me back $400. I don't expect it to be failing on a simple feature like an alarm. My Charge 2 never let me down once.
Because I've had trouble with this before, last night when I set it I went out of the alarm area and back in to check it was set up correctly. Checked and double checked.
Then, this morning, about 15mins AFTER my alarm was supposed to go off, I woke up when the watch slightly vibrated - it was prompting me for my passcode. I had been wearing the watch all night so I don't know why it was asking for the passcode. But it certainly didn't fire the alarm.
I don't think it's acceptable to have to reset the watch continually just in case my morning alarm doesn't go off. This needs fixing. Also I am now going to have to pay for the class at the gym that I didn't even get to attend, and I'm missed my window to exercise for the day.
06-13-2018 13:29
06-13-2018 13:29
This happens to me all the time too. Now I set my watch alarm and my phone alarm for 5 min later in case the watch doesn’t work. If it can’t read ur pulse in the night and resets the passcode, no alarm. If I have a shower at nigh and forget to renter the passcode when I put the watch on, no alarm.
I bought this watch because of silent alarms. I don’t want to wake up family with the loud phone alarm! I agree, it’s not good enough.
06-13-2018 13:32
06-13-2018 13:32
I did factory reset still not working correctly, I shouldn’t have to set it up over and over to have the alarm work. It’s inconvenient to have to re download apps etc
06-21-2018 06:25
06-21-2018 06:25
Yeah, that doesn’t work. I even wiped the device and setup again. Still no alarms. It’s obvioulsy a bug in the software. Update needed.
06-21-2018 12:54
06-21-2018 12:54
07-29-2018 14:43
07-29-2018 14:43
Is this planned to get a permanent fix applied? I have had the Versa for 4 weeks, twice the alarm has failed.
