07-30-2020
08:01
07:48
07-30-2020
08:01
07:48
My versa isn’t working correctly. I can get to the exercise modes but can not get the start button to respond. This has been going on for 4 days. Yesterday it started just flashing through random screens by itself. I have held the three buttons to restart it, charged it, changed the clock face to another Fitbit design( I was already using one). Any other ideas or thoughts on how I can fix this... it’s very annoying!!! Thanks!
07-31-2020 07:50
07-31-2020 07:50
Hi there @Pdm63, welcome to the Community Forums. Thanks for the details shared in your post about your Versa's screen behavior. I appreciate you have already tried to troubleshoot this situation before reaching us.
At this moment, the limits of what we can do for you here on the public community forums for the issue you're experiencing have been reached, so I've contacted our Support Team on your behalf to look into this issue further and provide you with some options. Please keep an eye on your email inbox for further instructions. Note that due to recent events affecting our operations, support options are limited and wait times are longer than usual.
We hope your issue is solved soon.
Best Answer07-31-2020 08:15
07-31-2020 08:15
My Versa 2 is dead. Only comes up with a whote screen. Its 50% charged and the app says that it was just updated.
What can I do?
Best Answer07-31-2020 08:47
07-31-2020 08:47
Hi there @Mwd2108, thanks for stopping by here. Thanks for the details provided in your post about your Versa 2's behavior.
In order for me to better assist you with this, please confirm that you've followed the steps below as described in the help articles:
If the suggestions don't work and your watch doesn't vibrate when you connect it to the charger, it may not be having a good connection with the charger and therefore, it won't properly charge. Said that, I recommend doing the following:
Give this a go and let me know the outcome, I'll be around.
Best Answer07-31-2020 12:48
07-31-2020 12:48
