05-16-2019
10:35
11:00
DavideFitbit
05-16-2019
10:35
11:00
DavideFitbit
How can I keep the screen on without tapping it
05-16-2019 11:14
05-16-2019 11:14
@trudiv Like keep it on all the time? That will kill your battery. You can change the setting for how long you want to stay on - go to Settings app on your Versa and scroll down to Display Awake section. You can also set Screen wake to Auto - this way the screen will turn on without tapping each time you lift your hand to check the time. To do that, log press the left button to access quick menu, go to Screen Wake and set it to Auto.
