12-01-2018 00:09
12-01-2018 00:09
Hi. Few weeks ago my Versa screen started showing blurry image on the sides of the screen. Battery started to last less than before. Any advice pls?
12-01-2018 00:28
12-01-2018 00:28
Is it only on the clock face screen? If so try another clockface and see if that fixes it. If it doesnt, try several restarts. If the problem persists you will need contact Support (link in my signature)
Helen | Western Australia
12-01-2018 19:37
12-01-2018 19:37
Mine is doing the same with other issues. Unable to fix it
12-02-2018 05:45
12-02-2018 05:45
@Oanas @SS_5 Welcome! It's good that the community is growing! Sorry to hear that your Versa screen isn't working as it should and your battery is draining quickly. Besides the great suggestion @NellyG shared you can try cleaning the contacts including using cotton with rubbing alcohol then charge it by plugging it for a couple of hours directly to your computer's usb port (try different ports) or use an UL listed usb wall adapter. After this restart your device and see how it behaves.
Let me know how it goes!
12-02-2018 06:12
12-02-2018 06:12
My fit bit versa started to not hold a charge for more than a day and then screen started flickering. Wont hold charge fir more than a couple hours. Less than a year old. Any help is appreciated
12-03-2018 11:54
12-03-2018 11:54
@lynneopny Welcome! It's great to see you around! Sorry to hear about your Versa having issues. Did you try the suggestions in my previous post? Please give them a try and let me know.
I look forward to your update!
12-03-2018 13:38
12-03-2018 13:38
Yes, I tried multiple things; soft reset/restart over 10 times in a few hour period, putting it back on the charger for a few hours, even attempted a factory reset with the buttons only even though screen was black hoping I'd get lucky but nothing helped. After spending 7 on/off hours attempting get it working, I did reach out to customer service via email and they were very helpful in my situation.
12-03-2018 17:14
12-03-2018 17:14
My whole Versa screen popped out in the middle of riding my bike and it won’t pop back I . Help.............Thanks!!
12-26-2018 09:38
12-26-2018 09:38
I’m very unhappy. My Fitbit Versa clock face has come off around the edges. It won’t go back! Gutted as it’s approx 6 months old and well cared for. Anybody had the same issue? What did you do? I hope Fitbit acknowledge the defect. I’m trying not to go to Apple for their version......
12-26-2018 09:38
12-26-2018 09:38
Mine too!
12-26-2018 10:04
12-26-2018 10:04
Hello ! We called customer service and they ended up replacing. It was only 6 mos and there was no fixing it.
12-26-2018 10:22
12-26-2018 10:22
Thank you so much for coming back to me. Hopefully I’ll get it replaced. It’s not a cheap gadget to buy....
12-26-2018 10:46
12-26-2018 10:46
They seem to stand by their products , you should call customer service. Good luck.
10-01-2019 12:49
10-01-2019 12:49
I have the same problem and I have tried everything, don't know what to do and not sure if they have customer support in Estonia.. It's not even a year old and it makes me so sad and disappointed.. 😕
