Versa screen quit working
ANSWERED
Yesterday my screen quit working.   I looked online and  have reset multiple times.  Anyone have any ideas to get it back working?  Also only 2nd green light is working.
1 BEST ANSWER
Accepted Solutions
7 REPLIES 7
Try installing a different clock face, preferably one from Fitbit.
That dis not work either.  It shook twice like it was changing.
I'm having the same issue and have had no luck with changing the clock face 😔
I wonder if it is a Fitbit issue all around?  I guess I will try to email them direct.
Hi I had the same issue. Don't bother emailing as this can take days, phone them instead, they will go through checks with you and if there is a problem they will send a new one out. Much quicker. Hope that helps.
Thanks.  I called them and they are sending me a new one.
