03-24-2020 10:43
03-24-2020 10:43
I can no longer swipe the face of my Versa. If I push the left button it goes to the run option and I can start that but nothing else. I tried re-starting 6 times but no different. I can see the output on the app but I can’t change the exercise settings.
03-27-2020 10:33
03-27-2020 10:33
@SunsetRunner Thanks for confirming. Please open a new thread on the Surge forum if the problem still persists. There are Surge experts there who can definitely assist you. Thx!
Best Answer03-24-2020 12:02
03-24-2020 15:43
03-24-2020 15:43
I am also having this problem. I was instructed to do a hard reset a few weeks ago and after finally getting everything downloaded again it worked okay for a few weeks. Now it’s back to not working again.
03-24-2020 18:31
03-24-2020 18:31
@hansmith Is the screen black? Are the LED lights ON?
Best Answer03-25-2020 01:45
03-25-2020 01:45
03-25-2020 01:46
03-25-2020 01:46
Best Answer03-25-2020 01:47
03-25-2020 01:47
Best Answer03-25-2020 04:09
03-25-2020 04:09
So I have been dealing with this for weeks and it's getting frustrating. I too cannot swipe the screen. When my alarm goes off I tap the check mark and nothing happens. I've cleaned the device's face and on the backside and I still can't shut off the alarm. The only thing that seems to work is when I push the left button. Other than that, the Alarm won't turn off. When I try to use the timer, the same thing occurs. I push the button to start the timer but I can't get it to start. I'm going to try a hard reset.
Best Answer03-25-2020 06:30
03-25-2020 06:30
Best Answer03-25-2020 07:21
03-25-2020 07:21
Yes I have. Any other ideas?
Best Answer03-25-2020 07:24
03-25-2020 07:24
So if nothing works to reset it, what do you recommend? Will Fitbit replace my Versa?
Best Answer03-25-2020 07:39
03-25-2020 07:39
Best Answer03-26-2020 11:46
03-27-2020 00:30
03-27-2020 00:30
Best Answer03-27-2020 10:33
03-27-2020 10:33
Best Answer03-27-2020 10:55
03-27-2020 10:55
Best Answer03-27-2020 12:34
03-27-2020 12:34
How do you do a hard reset on your watch I’ve done the 2 button one but nothing still works screen is still frozen
