04-24-2019 06:54
04-24-2019 06:54
My versa screen is un-readable when outside in the daylight/when sun is shining. I've tried selecting a different clock face to see if it was just a particularly dull clock face, but I'm still struggling when outside to see any information on my screen. I've previously had a Charge 2 which was perfect for display brightness. Is there a way to increase the brightness on the screen?
04-24-2019 07:03
04-24-2019 07:03
Hi, press the settings on your Versa and on top of the screen you will see "brightness" . By pressing it, you can change it to: Normal - Maximal - Automatic - Dimmed. The default setting is either normal or automatic. Choose maximal when outside.
04-24-2019 07:03
04-24-2019 07:03
04-24-2019 07:21
04-24-2019 07:21
Perfect! This has solved my issue. Still getting used to all the new things this Versa does 🙂
04-25-2019 09:42
04-25-2019 09:42
@hheapy Welcome to our Fitbit Community! I'm so glad to hear that you managed to get the issue resolved after following the great advice that shared my friend @SunsetRunner!
In addition, I'd like to share the Versa's manual so you can learn all its features and get the most out of it. Also, I'd like to invite you to visit our Discussions board where you can share your experiences, meet people and create new topics.
Hope to see you in our Fitbit Community more often! 😀
05-19-2021 15:01
05-19-2021 15:01
I have the same issue. Except when I press settings the “Brightness” option is a faded color and will not allow me to select it to change. This is also the same for the Do Not Disturb and The Screen Wake. All other options are bright and allow me to select them.
yes I’ve restarted/rebooted the Fitbit MULTIPLE times. Any suggestions????
Best Answer05-20-2021 00:32
05-20-2021 00:32
@kelly6909 You are probably in in Sleep mode
On the watch Swipe down once from the very top It will show your notifications Swipe down again from the very top Click on the two white bars to get to Quick Settings Make sure moon [sleep] icon is grayed out
The manual is here |
