@ainsleym4 How long did you have your Fitbit before it would not respond to touch? I am having the same problem. I am told there is nothing they can do and I have to buy a new one.
Best AnswerI had mine less than a year ..... but they replaced mine. Contact them on Facebook Messenger, they were really helpful.
Best AnswerThank you! I did the same and after the logo showed up, I let go of the bottons , it came back to life! Thank you
Best AnswerDoes anyone else think they should make a recall for this?
It seems like it's happened to so many of us, and to many of us after the warranty has expired.
Best AnswerYes I am having the same problem with my Versa, have tried the reset, but same problem with unresponsive screen.....did anything work inbthe end or did you just give up?
Best AnswerHi! This has happened to me recently. Tried to do a factory reset multiple times but the swipe right, up and down doesn’t seem to work. Also I can’t seem to press start for a workout. Is there anything else I can do?
Best AnswerThank you for letting me know! This also happened to my father, so he switched to Garmin. Mine is under a year, so I will try and get it replaced.
Best AnswerUninstall app from phone.
Set up new alternate email account that your versa not been registered to before
Press all three buttons on watch and put in its charger.
Install new Fitbit app using new email address as contact.
Put phone in blue tooth find new device...once found Fitbit code will appear on watch the code will be requested on your phone. Enter on phone and then follow rest of instructions...it may take all night to charge both phone and watch must be left charging. Phone can be used whilst the download takes place. .
Fitbit help line could not correct my original issue of frozen home screen and rotating languages screen and offered me a discount off a new phone ..now not needed. Please try the above before investing in a new Fitbit.👍
