Mine is getting replaced under warranty. There is definitely something wrong with the touch screen!
01-15-2020 12:58 - last edited on 06-19-2020 18:25 by LiliyaFitbit
I had it happen twice. They replaced it the first time - but the second time, the watch was past the warranty date for the original watch - so no other replacement.
Best AnswerI have had 2 Versa lites in the last year and a half , both have become unresponsive to swiping. They replaced the first one so I hope they replace the second. I have tried restarting I now have a message that says Data not cleared Sync and try again. How do I sync if I can't swipe my screen.
Best AnswerThis is happening to me now on a daily basis whenever I don't touch it for a while. Restarting sometimes works but it's very frustrating. I had no such issues with the Alta HR and I'm very disappointed from this product
Best AnswerI just did a factory reset and it’s still not working. The buttons aren’t even working now.
I followed the instructions and it did a factory reset but now I can’t set it up as the screen is still unresponsive.
Best AnswerI rebooted my versa and now it won't open up it won't connect to the phone it won't do nothing it's just the screen has a logo that's it
Best AnswerMine can connect to my app - kind of. It’s let me add the versa as a device, but I can’t follow through with the instructions on the watch screen! So it’s pretty useless now! Not impressed with this at all.
Best AnswerI've had the same issue and they are not replacing mine either. I'm glad some others were able to get a replacement, but with this many complaints on the same issue this is clearly an issue with the device. I have purchased many fitbits over the years so really bummed to have to pay for a new one after just purchasing this a little over a year ago. 😔
My last fitbit lasted about that long also before a manufacturing issue, so I guess we have to plan to buy one yearly.
Best AnswerYup, this process did not help me either, while I did try it several times. Fitbit would not replace mine either, even though I only had it for 13 months, when it failed. I too have had several other Fitbits that have failed previously. This is my last one. The next will be an apple watch.
Best AnswerMy wife’s has now got the unresponsive screen after 7 months of ownership...I want to fix it without going through warranty, but I can’t even get it to do a factory reset...
Following the instructions to a tee...no luck what so ever...
Can you factory reset from the app?
Best AnswerThanks for the tips - What is the FB Messanger contact? Am I missing it here somewhere on the site?
Best AnswerGo to their page on FB ... It’s just called Fitbit (with the official blue check mark next to the name) then click on ‘message’. They usually reply within a couple of days.
