09-30-2018 23:15
09-30-2018 23:15
04-24-2020 05:07
04-24-2020 05:07
@ainsleym4 How long did you have your Fitbit before it would not respond to touch? I am having the same problem. I am told there is nothing they can do and I have to buy a new one.
Best Answer04-24-2020 11:17
04-24-2020 11:17
I had mine less than a year ..... but they replaced mine. Contact them on Facebook Messenger, they were really helpful.
Best Answer04-25-2020 06:59
04-25-2020 06:59
Best Answer04-25-2020 17:12
04-25-2020 17:12
Best Answer04-27-2020 20:33
04-27-2020 20:33
Thank you! I did the same and after the logo showed up, I let go of the bottons , it came back to life! Thank you
Best Answer04-29-2020 07:40
04-29-2020 07:40
I am glad that it worked out for you. Unfortunately mine is still unresponsive.
Best Answer05-06-2020 19:16 - edited 05-06-2020 19:17
VERSA Fittbit fully charged, app updates perfectly. Touchscreen completely stuck- non responsive, impossible to shut down. How to proceed?
Best Answer05-06-2020 19:20
05-06-2020 19:20
Contact them via Facebook Messenger ... the page is Fitbit with the blue official check mark.
Best Answer05-07-2020 06:43
05-07-2020 06:43
Does anyone else think they should make a recall for this?
It seems like it's happened to so many of us, and to many of us after the warranty has expired.
Best Answer06-18-2020 13:08
06-18-2020 13:08
I have tried all the tricks and it is still not working I can feel it buzzing but screen is completly unresponsive. I have had this watch for over 2 years and it has always served me well. I am so sad.
Best Answer10-14-2020 14:26
10-14-2020 14:26
Yes I am having the same problem with my Versa, have tried the reset, but same problem with unresponsive screen.....did anything work inbthe end or did you just give up?
Best Answer02-15-2021 11:36
02-15-2021 11:36
Hi! This has happened to me recently. Tried to do a factory reset multiple times but the swipe right, up and down doesn’t seem to work. Also I can’t seem to press start for a workout. Is there anything else I can do?
Best Answer02-16-2021 02:59
02-16-2021 02:59
02-16-2021 03:06
02-16-2021 03:06
Thank you for letting me know! This also happened to my father, so he switched to Garmin. Mine is under a year, so I will try and get it replaced.
Best Answer03-11-2022 08:38
03-11-2022 08:38
Uninstall app from phone.
Set up new alternate email account that your versa not been registered to before
Press all three buttons on watch and put in its charger.
Install new Fitbit app using new email address as contact.
Put phone in blue tooth find new device...once found Fitbit code will appear on watch the code will be requested on your phone. Enter on phone and then follow rest of instructions...it may take all night to charge both phone and watch must be left charging. Phone can be used whilst the download takes place. .
Fitbit help line could not correct my original issue of frozen home screen and rotating languages screen and offered me a discount off a new phone ..now not needed. Please try the above before investing in a new Fitbit.👍
Best Answer03-23-2022 13:26
03-23-2022 13:26
This worked!! It's been the Best instructions I've found. I did have to hold those last two buttons nfor what felt like forever though.
04-03-2022 08:38
04-03-2022 08:38
