08-28-2021
04:57
09:02
08-28-2021
04:57
09:02
My versa screen has turned black. Can’t reset. This problem started 5 days ok. Tried resetting hasn’t solved my problem.
08-28-2021 06:08
08-28-2021 06:08
It could simply be the battery is flat by now.
Try charging it from your computer as it makes a sound when its plugged in so you know the connection is good and its charging?
Best Answer08-28-2021 09:01 - edited 04-29-2024 05:51
Hi there, @Shawo21. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa. @Guy_ Thanks for your help!
I've seen that you contacted our Support Team after posting here to report this issue. Please stay tuned to your inbox, someone will reach out to you soon.
Best Answer08-28-2021 10:59
08-28-2021 10:59
If I try to turn on it by power button it respond very very late
Best Answer08-28-2021 13:41
08-28-2021 13:41
