01-14-2020 17:52
01-14-2020 17:52
If I use my Versa as a connected watch (e.g. when riding my bike) it shuts down when it gets to 25% power. I need to restart it by resetting it (pushing two buttons simultaneously). This is really annoying because it means I often don't capture a big chunk of my exercise. Is this a known issue? Is there a fix?
01-14-2020 18:00 - edited 01-14-2020 18:04
Hi @Peter_the_SBAM , it's a safety precaution by Fitbit when it recognizes that you're doing an exercise with a battery of only 25% in order to not deplete your battery entirely. Normally you will get a notification that your battey is low and needs charging asap when on 25%. regards kuzibri
Best Answer01-14-2020 18:00 - edited 01-14-2020 18:04
Best Answer01-17-2020 02:05
01-17-2020 02:05
Many thanks. That's very helpful. Peter.
