06-26-2019
22:28
08:44
JuanJoFitbit
06-26-2019
22:28
08:44
JuanJoFitbit
Had my versa since Jan, no problems, I have Samsung s7 edge. Followed all troubleshooting tips. Syncing is intermittent, clock shows incorrect time. Just stopped working, Seems to sync when I charge versa, but that not worked for the past 5 days......help!!!! Tried everything.?
Moderator edit: format
06-27-2019 08:44
06-27-2019 08:44
@Hms812 welcome to our Fitbit Community! I'm happy to assist you with your Fitbit Versa since it stopped syncing. By the way, thank you for troubleshooting this issue before contacting our forums.
In order to avoid providing the same information, I'd like to know what troubleshooting steps you have tried. In the meantime, please try the troubleshooting steps that are listed in this help article. This article may contain the steps that you already tried but you can skip them and proceed with the ones that haven't been performed.
Keep me posted! ![]()
Best Answer06-28-2019 00:35
06-28-2019 00:35
Best Answer06-28-2019 03:19
06-28-2019 03:19
I'm having the exact same issues. It's annoying. I have a Samsung S7. I've done all of the same steps trying to fix it and I'm still having problems.
Best Answer07-02-2019 11:51
07-02-2019 11:51
Best Answer07-02-2019 15:14
07-02-2019 15:14
I have an S7, also, that several of us have in common.
Not sure this will help it but I had the same no-sync problem with my two month old Versa (after the recent software upgrade). I uninstalled the Fitbit app and then removed it from my phone's pairings in Bluetooth. Then reinstalled the app, paired it, and it was fixed. Good luck.
