07-20-2019
17:35
07:45
07-20-2019
17:35
07:45
My Versa stopped syncing and I did a factory reset thinking the watch had issues. Uninstalled/reinstalled app. Cannot pair watch. Online it appears there is a major issue with software. Any ETA on a fix so I can use my watch again?
07-24-2019 08:17 - edited 01-27-2024 12:57
Welcome to the Community Forums @jjfontanilla. I'm sorry for the late response. Thanks for trying to solve the syncing issue with your Versa prior to contacting us.
While reading your post I was wondering if the mobile device you're syncing with is included in our list of supported devices? You can see the list at: Which phones and tablets can I use with my Fitbit watch or tracker?
Please keep in mind that when a device is not supported we cannot guarantee its functionality with the Fitbit app. It might work at a certain time and then it can stop working out of nowhere after an update. This is because the app is not optimized to that device and any change could impact the performance.
If you've not done so, I'd suggest to try the following:
1. Remove the Versa from the phone's Bluetooth settings
2. Turn off other Bluetooth connections when not in use.
3. Plug it into the charging cable and open the Fitbit app.
4. Setup your Versa as a replacement.
Let me know if there's anything else I may do to assist you with.
07-24-2019 09:44
07-24-2019 09:44
07-25-2019 13:16 - edited 01-27-2024 12:56
Hi there @jjfontanilla, thanks for coming back and following the tips and recommendations I've provided above.
I went ahead and created a case for you with our Support Team. Someone will reach out to you soon to offer their assistance. Please keep a lookout in your inbox to the email address associated with this account.
Let me know if you have any questions present.
07-25-2019 13:27
07-25-2019 13:27
Thank you.
07-25-2019 14:49
07-25-2019 14:49
You're very welcome @jjfontanilla! I'll be around if you need anything else. I hope you have a great day!
