09-24-2020
12:02
07:26
09-24-2020
12:02
07:26
My watch was showing over 2hrs ahead of time. I tried to sync it with my samsung a90 phone. Wouldn't do anything so attempted a factory reset. Now it just tells me on the watch screen it couldn't delete all data, with a large X and tells me to sync again. I cannot do this either as no way to sync.
Any help would be appreciated because otherwise the watch is useless. Purchased not even a year ago. Thanks
Hi there @Alfie7, welcome to the Community Forums. I'm sorry to hear about the recent issues you've been having with your Versa, I understand where your concern is coming from and how you must be feeling. Thanks for the details provided in your post and for your efforts in trying to fix the syncing difficulties prior to posting here.
Please note that the error message you're now receiving on your watch's screen ("Data not cleared, Sync & Tried and again") usually appears when you've performed a factory reset without first unpairing the watch. Said so, please try the steps below:
If you can't get started with your Versa, usually a missing requirement is the cause. Carefully review the requirements provided in the help article: Why can't I set up my Fitbit device?
Give this a go and let me know if after linking your watch again it continues showing the wrong time. I'll be around, keep me in the loop.
Hi there @Alfie7, thanks for getting back and for the update.
Since the steps above haven't worked, at this time I'd like to suggest doing another factory reset by following these steps:
Once you've done the factory reset, please try one more time the troubleshooting steps provided here.
I'll be keep an eye on your reply.
