Versa stopped working
ANSWERED
my versa just died.. Try to charge it, nothing.. No life...
1 BEST ANSWER
Accepted Solutions
Hi there @Larissa71, thanks for stopping by. Thanks for the details provided in your post about your Versa's behavior and for trying to charge it. I'll be glad to help you.
As per the description of your post it seems that the battery on your watch may not be charging properly and therefore does not turn on. I recommend that you follow these steps (or please confirm that you've followed them as described below):
  • Clean the charging contacts on the back of your device and the pins on your charging cable using the instructions in How do I clean my Fitbit device?
  • If the error "insufficient power source" appears on your device's screen, remove other devices plugged in to your power source, or plug your device in to another source.
  • Try a different USB port or a UL-certified wall charger.
  • Check the alignment and try reconnecting your device to the charging cable. For more information, see How do I charge my Fitbit device?
  • Restart your Fitbit once again. For more information, see How do I restart my Fitbit device?
Let me know if this helps you, I'll be around.
1 REPLY 1
