08-12-2020
15:47
20:05
EstuardoFitbit
08-12-2020
15:47
20:05
EstuardoFitbit
My Versa Stopped Synchronization so I performed a Factory Reset only After nothing else worked, after the Pebble wouldn't Start Up. I called Customer Service was told too Bad out of Warranty go Buy Another One. Which there's no Way!
08-15-2020 04:33
08-15-2020 04:33
Hi there @SunsetRunner, thanks for stopping by in the Community Forums. We acknowledge the limitation we have on our part particularly on what you have experienced. We‘re taking into consideration your comments and sentiments with regards to our products and services.
Please know when a Fitbit devices is deemed defective we review eligibility using the one year warranty option. For our full warranty terms and conditions, see our Return Policy and Warranty.
Our products are indeed designed and made to last (this goes for each product component) however, there is not an infallible way to ensure that no issues will be present in the long run. Because of this, our Warranty Policy is set into providing as much coverage as we can.
I understand that the outcome of your case with our Support Team is not fulfilling your expectations, but keep in mind that every case is completely different from the other's, thanks for taking the time to share your experiences and feedback. For more information about the outcome of your case, please get in touch with our Support Team again and also, you can check our warranty policies here for a better understanding of the information that they provided to you.
I'll be around if there's anything else I may do for you.
Best Answer08-15-2020 05:15
08-15-2020 05:15
Bought 2 Fitbit Versa 2 watches from Costco, one in November 2019 and one in December 2019. Both have stopped working. Have tried factory resets (working through online tech support) multiple times and watch still does not work. How can I get an RMA for return?
05:55
06:33
08-15-2020
05:55
06:33
Same thing happened to me I was like 2 weeks past the 1yr warranty! No way I'm spending more money on a product that just quits working
Moderator Edit: Formatting
Best Answer08-15-2020 10:12
08-15-2020 10:12
Best Answer08-15-2020 11:43
08-15-2020 11:43
Same happened to me! Luckily I am still in my warranty by a few weeks! I'm calling Monday morning!!!
Best Answer08-15-2020 12:06
08-15-2020 12:06
Best Answer08-15-2020 13:03
08-15-2020 13:03
Website says customer service hotline only open M-F. I did leave message for a chat.
