08-21-2021 16:58 - last edited on 08-22-2021 11:18 by LiliyaFitbit
Completely stopped working third watch , won't be buying again , only had 2 years overpriced and always problems .
08-22-2021
07:03
10:55
08-22-2021
07:03
10:55
There are issues currently with watch batteries going flat quickly. Check that the battery isn't flat, just in case its that simple.
Recommend plugging the cable into a computer and then attach the watch and listen for a connect sound, which will mean its getting power.
While its charging try and do a sync with the Fitbit App. It may sync if only the screen is broken, which is another recent problem introduced by firmware updates.
On the off chance its a clock face problem and it is syncing, trying changing the clock face from the Fitbit App, Clocks tile.
Best Answer08-23-2021 11:50 - edited 08-28-2023 09:42
Hi there, @Frank07845. Welcome to the Community Forums. We‘re taking your comments and sentiments in regards to our products and services into consideration.
I've seen that you reached out to our Support Team after posting here and they've already assisted you with this matter. If you have any further questions regarding the outcome of your case, please feel free to contact our team back so they can continue assisting you.
